Upgrades
Castle Rock, CO, USA
I purchased my 2020 ST used. The person had a Borla exhaust installed. What else would he have done and how can I tell?
1. Seems lower but I can never find another ST to see if it was. Don't want to be the creepy guy in a parking lot with a measuring tape but....
2. How can I tell if he put a Whipple IC in? Looking through the grill I see it going down past where the license plate goes.
What else to look for?
lwlf13
Haymarket, VA, USA
Springs and rear swaybar are visible through the back tire. Stock are black, h&r springs are blue-gray and Steeda are bright blue. Steeda rear swaybar is bright blue, you can’t miss it.
Dealership can let you know if the ecu was ever flashed.
You can find a comparison of stock intercooler vs. whipple on this forum. It’s a big difference. Should be able to confirm with a flashlight.
Can check for wheel spacers if the wheels are flush/nearly protruding.
J
Thanks!!! Just saw the blue Steeda springs! Dang, he is taking the fun out of it. The IC has to be a whipple, it's way bigger than the stock picture I saw.
Make sure you’re not looking at the radiator. The oem IC is way up high. 371109A9-E7C0-44AE-97D9-EE7EF4769F5A.jpeg
J
J
Another quick question- I confirmed that the ST I bought has Steeda springs. No idea on any other upgrades (thank you Unbroken for the IC confirmation). I am assuming it was lowered and when you do you should do an alignment. Dealership said $99, a great auto repair shop said $99 but if the computer needed to be relearned it would be another $125.
Should I do it just in case the previous owner didn't? And, do you think that the dealership would spring the extra $ if it needed the "relearning"?
