LED license plate upgrade
Ordered these. Plug and play solution. No resistors of Forscan necessary. Light is also oriented correctly as opposed to when changing bulbs in existing housings.
These are the ones I ordered.
Everbuilt LED License Plate Light Compatible For Ford Explorer Fiesta Fusion Escape MKZ Bright White LED 2011 to 2018 Ford Explorer/Fiesta 2013 to 2018 Ford Fusion/Escape 2015-2018 Lincoln MKC
https://www.amazon.com/dp/B07QDFFLN...abc_Q78KNKT2VCW3DRG4MD3Z?_encoding=UTF8&psc=1
Also had every intent of changing our turn signals and reverse lights but then this happened
. Have to get around to drilling out. Already tried to slot with dremel wheel but no dice. Feel free to recommend extraction bits you’ve used in the past
