I purchased https://www.ebay.com/itm/Front-Rear...-/124304348169?_trksid=p2349624.m46890.l49286 off EBay for $32.50.
The splash guards look good, plastic is flexible and seem to be good quality. I have nothing to compare them to so I don't know how similar they are to factory Ford splash guards.
The rear guard install was straight forward, remove the 4 7mm bolts that match the holes in the guard and put them back in. The bolt furthest in the wheel well is tight to get to with a 1/4" drive ratchet and standard length socket. I used a deep socket on the other 3 bolts so the ratchet would clear the fender and guard.
The front guard was a little more involved as there is only one hole in the guard for a 10mm bolt under the fender. The upper part of the guard is meant to be held on by clips but the clips are to big. I squashed the clips to hold tight but the upper part of the guard would slip out. Also included in the kit are 4 metal screw retainer clip thingys and a bunch of Phillips screws. I drilled 2 holes in each front guard and used 2 clips and 2 screw to secure them better. I also slipped on one squashed clip per side just because.
- Show All
