I apologize if someone has already answered- Forscan codes for ST?
LokiWolf
Henrico, VA
#81
Haven't seen the "Enabled Use Fog Lamps as Cornering Lamps" option before in the forscan lists.
Yep, been in the drop down easy config settings for over a year.
People, stop using actual coding, use the drop downs, FAR less risk. You just reverse it if it doesn’t work.
Sent from my iPad using Tapatalk Pro
Ashburn, VA
It's selectable option, here's an informative video on FORscan usage - FORScan F150 mods. New easy way with no spreadsheet! - YouTube . Fast forward to ~6 mins. to bypass connecting, etc. The option to use fogs lights as cornering lamps is shown on the screen at 13:00 minutes.
San Diego, CA, USA
#83
To turn off the enhanced engine noise, the first line in ACM (727-01-01), 6th digit is a 4, and should be set to a 0 or 9. I set mine to a 9 because I read that a 0 completely disables the dash speaker. Because the stock exhaust is so quiet, I ended up turning it back on.
I can not find the ACM page/screen. I get this far and am scared to adjust something. Please advise.
San Diego, CA, USA
#84
Can I access the FENG and ANC throught these drop downs? I can't find the ACM page only this page (see attached)
Calgary, AB, Canada
#85
Which dongle are you using? I had to switch to the OBD link EX after I couldn’t connect to the ACM module with my ELM327.
