Got Board
hdzrt
High Desert CA
Put my boards on today. Nice fit and finish, bolted right up.
Snailfly Fit for 2020 2021 Ford Explorer Side Steps Running Boards Black
Good bang for the buck...:cool:
But why? Just for looks?
Autoworker
Like your play on words.(y)
Elk Grove, CA, USA
hdzrt
hdzrt
High Desert CA
More or less for the looks, I think it completes the look. One benefit is i can open the doors and stand on them to reach and to clean the front window and the top.
hdzrt
hdzrt
High Desert CA
Is the pinch weld still useable to jack the car up?
See attached picture of the brackets, there are 3 of them that bolt up to OEM holes. not sure you can jack the car up from pinch weld, I use a car hoist in my shop. Bracket.jpg
Elk Grove, CA, USA
See attached picture of the brackets, there are 3 of them that bolt up to OEM holes. not sure you can jack the car up from pinch weld, I use a car hoist in my shop. View attachment 5458
Thanks for photographs. Most likely the brackets cover the jack points.
Elk Grove, CA, USA
Just checked my 2021 and I do see the factory three bolt holes. Looks like the original jack points are still open after you install the brackets. Did you have to drill through the plastic trim for the bolts?
Do these feel sturdy when you stand on them?
Asking for a 210 pounder.
thanks for all the information
Elk Grove, CA, USA
Do you have a link to where you purchased them.
hdzrt
hdzrt
High Desert CA
No drilling, you slip a ps of flat stock (that is provided) that has two threaded holes between the pinch weld and plastic for the two bolts, Very sturdy. I'm 190lb and i jumped up and down on them after install. those steel brackets and alum boards are heavy duty. The pictures i posted suck, much better looking in person.
KozzyJr
Sudbury, ON, Canada
Which brand are these running boards. Also did your factory mudflaps still work with these running boards
hdzrt
hdzrt
High Desert CA
CGainz
NYC, NY, USA
Ashburn, VA
