….Not to mention you gave us SO much crap for using somebody else's tuning....yet here you are. You are a hypocrite sir. This is exactly why ZFG tunes my ST. Because he knows it better than anybody and has a proven track record on the ST, and MANY other Fords!
….I have done small changes and tweaked a few things. Mostly I leave it up to Adam@ ZFG. Again, could I add power myself, yes, but get as much as Adam@ZFG out of it, Nope. He is the Master!
The code on the new Ford 10Spd's is larger than the ECM's. Good luck. Adding power to the ST without factoring in tweaking the 10R60 has been proven to be a bad idea. Heck one tuner's tunes made it worse a few times. You better know what you are doing before messing with that Trans. This ain't that 4 Speed you messed with in the past!
No, not a hypocrite for using someone else's product while waiting for my preferred platform. I purchased the HPTuners earlier MPVI1 Pro setup, but I don't like the GUI they use, plus the table arrangements suck. HPT is also missing many functions that Cobb includes. HPT latest version includes a few interesting tables that would be great if applicable to the ExpST, but they're non-functional to date, even in the beta version. SO I just shelved it and waited for the Accesstuner from Cobb. The Cobb AP is a MUCH more user-friendly and capable device for quick & easy data logging, quick changes to ECU functional options right from the AP at the vehicle. The only engine functional item I see in HPT that isn't in Cobb is the 2-stage oil pump settings. Anyway, I've done all the current tuning on my Raptor with Cobb Accesstuner.
ZFG Adam indeed does great work. He visits the Raptor forum and has done a few Raptors as well. There was one for sure he tuned with the CRP Stage-4 bolt-on turbos. The guy said it ran great until it popped. I'm sure Adam didn't do anything to cause it. From all the information available it was operator error with maintain adequate oil level. Tuning for reliable power is quite a tough process as I've done it. I certainly respect a few of the business tuners because I know the work involved to gain that intellectual property. That said, there is no magic involved, just dedicated work at the task. I'm quite familiar with the Cobb platform and they had already announced their interest in the Raptor, so I bought the MPT as the interim, nothing more.
I can see why you prefer ZFG Adam to do your tuning rather than learning it yourself though. It sure is easier... BTW, if Adam does your tuning, he (and all other tuners) locks the tunes to protect his intellectual investment, so how do you access the vehicle to make those changes and tweaks? Do you mean that was before you bought into ZFG?
As for the 10R60, you're correct. I'm certainly not ready to claim victory over knowing it fully, but it will happen,, eventually. Likely a bit later rather than earlier as the ExpST is the wife's DD. The Raptor, Focus RS, and bikes are my go-to toys.
I do have some photos of my Focus RS forged engine "build" I should post up. I've popped 2 Direct Injection engines (1-Ford + 1-Mazda) before I finally learned the root cause. The Mazda 2.3 failure was back in 2008 when there were OEM stock engines popping, but we didn't know wtf was causing it. Even Mazda didn't know yet. They were the first wide-spread sellers of cars with Turbocharged Direct Injection Spark Ignition (DISI) in their MazdaSpeed division. Yes, I'm was my own tuning with Cobb products. The root cause is/was LSPI due to the then-current SN motor oils! It took some frustrated digging to find out the how/why, but I do learn eventually! Now, it's a common knowledge topic.
