Just in case anyone is thinking of making any of these exterior modifications.... a photo is worth a thousand words. Painted UNBROKEN's old mirror caps Rapid Red BASF Glasurit D4 which were matched to the actual door paint using some sort of new scanner camera setup. You will need a ball end std hexagon allen wrench to get the two screws off to remove and replace. I suggest you magnify the wrench first (two piece magnet with hole in the middle, pass the wrench end through the hole several times which will impart a magnetic charge into the allen wrench) so you don't lose the loose screw in the mirror assembly. Tape the screw onto the allen wrench for the install. The front and rear badge are OEMautoart, painted the same Rapid Red BASF Glasurit D4. The front Oval was installed using UNBROKEN's method without removing the grill. The red rocker molding lettering is from UPR. I was wondering if anyone had installed the red UPR Explorer lettering on the tailgate yet? Please share some photos if so as I have them on hand but sitting on the fence about installing them yet. May be red overkill??
- Show All
