Towing w/ the ST
SR412
West Hartford, CT, USA
Greetings from a new member. I am currently looking for a new SUV and have a 20ft., single axle camper I need to tow. I have narrowed my choice to the Explorer ST and Durango R/T. Can anyone tell me why the ST makes considerably more HP and torque (400/415) vs. the R/T (360/390) yet is rated to tow less - 5600 vs. 7400 lbs.? Thanks!
Dallas, TX, USA
transmission, differentials, gearing, brake size, cooling ability, etc... all play a roll. Without knowing the differences in the Durango and Explorer in those areas its hard to know. I'm GUESSING the ecoboost is harder to keep cool vs. the Hemi with the turbo's adding to the heat load.
The 10R60 has a rating of 600nm or about 440 ft. lbs. of torque.
The 8HP70 has a rating of 700nm or about 516 ft. lbs. of torque.
The AWD system in both could also be limiting unless you are looking at the R/T rear wheel drive. The PTU(transfer case) in the Explorer uses a clutch setup to regulate power transmission. Im not sure what the limit on that is, but im sure somebody on here has exceeded it LOL.
Ontario, Canada
I imagine it is unibody versus body on frame. My GMC Sierra only has 330 hp and it is rated to tow 9500 pounds, but it has oil and transmission coolers and a heavy frame.
Vango54
Naples, FL, USA
The Lincoln Aviator which is basically the same chassis as the Explorer but has the 10R80 Transmission to the Explorer ST 10R60. Aviator can tow 6800lbs.
The Aviator is rated the same as the ST unless you have the towing package. With that also comes a class IV tow hitch vs the class III in the ST
Ontario, Canada
Nope, back to body on frame.
Ontario, Canada
Don't get me wrong, I love my ST. But if I needed to tow regularly and didn't have a half-ton I would be picking something with a frame.
Dallas, TX, USA
Shit... nice. The article I saw was dated 2020, I didnt know the 2021 was a whole new re-design. Based on the Ram 1500... Yea thats going to be a way more capable tow vehicle than the ST.
S
SR412
Thanks to everyone for the info. Please comment on towing experiences w/ the ST.
S
SR412
Approx. 4400 lbs. Single axle 19 ft. E-Pro camper. We tow approximately 1 weekend/month.
Dallas, TX, USA
electric trailer brakes? Weight distributing hitch?
The explorer is supposedly wired for them, just got to get the correct adapter for the brake controller. I know a few people here have them.
Im looking at buying a boat that will be pretty close to the max tow rating, but, beyond wherever I buy it from, I wont be towing more than 1/2 mile to the boat ramp from my house. Im unconcerned. I know the brakes and engine are up to it. The trans should be, in theory. Like was said before the main limit appears to be a Class III hitch(6k lb limit) vs. a Class IV hitch(120000lb limit) because the Aviator and Explorer arent THAT different.
S
SR412
Have both trailer brakes and a weight distribution hitch, We travel the New England states so some trips are 3 hours.
Currently towing with a 2009 Honda Pilot (134k miles) which struggles on hills and gets brutal gas mileage. The Pilot has had a tranny flush, has a tranny cooler and air lift suspension in the rear - about the best I can do with this model.
Looking at both the ST and the Durango R/T. Like the ST better just want to do my homework.
Socal
Not true, both have the same 10R60 tranny. The Hybrid Aviator and Explorer are only the only one's equipped with a 10R80MHT I believe tranny, which is slight different from the Mustang's 10R80 tranny.
The new 2022 Explorer's can be equipped with a Class 4 hitch, more than likely it'll have the same tow rating as the Aviator, 6,800 lbs.
North Shore MA
I tow an 18' Whaler with the ST. Between 3.5K and 4K lbs, boat, trailer, and gear. Single axle trailer, no brakes. No issues whatsoever. My previous 3 vehicles were 5.7L Hemi Grand Cherokees with 7,200 lb towing capacity. I think the ST tows my setup just as well.
I also towed my cousin's new 22' boat, dual axle trailer, no brakes, about 1/2 mile to a ramp. Probably pretty close to the ST's max capacity. It's not so much the towing as it is the stopping. I'm not sure I'd want to do any extended towing with ANY vehicle at or close to max capacity.
S
SR412
Thread Starter #17
Great info - thanks. Electric brakes on the trailer make a world of difference.
Ddrummer
Frederick, MD, USA
I have a 2020 ST and pull a 27’ travel trailer (23’ box) with a dual axle weighing 4,200 lbs dry with a weight distribution hitch and electronic trailer brake controller. We’ve taken it on 5 camping trips this year, 2 of which were 1000 mi round trips in tow. These 2 trips took us through the mountains (Smoky’s and Pisgah Nat Parks).
It pulls very well for its size but like someone said earlier that it’s not the pulling but the stopping which is most important. I had one white knuckle experience going down a mountain highway when a driver in front of me decided to stop when I was building speed on wet pavement. I didn’t hit anything but I did lose traction. More than anything it was a learning experience. The tow mode works really well, especially on hills. Once you plug in the 7pin it pops up on the screen that a trailer is connected and asks for the length so that the blind spot warning is extended (based on the total length of the trailer and truck) as well as disabling cross traffic when backing up. Depending on terrain I average between 9-11 mpg’s assuming approx 4,800-5.000 lbs w supplies and empty (white, gray and black) holding tanks.
Fresno, CA
2022 Ford Explorer ST - STAR WHITE
My 2022 ST window sticker lists the towing package as a Class IV.
Does the window sticker also show the 52T option? That's the option for the class IV tow package.
