The coupling between the center muffler and the passenger side tail pipe failed on my 2020 ST. In looking at the pipe and the coupler on the muffler they both have corrosion and there is soot marks above the joint. It would seem to me that a small leak started at the top of the coupling and eventually the weld/coupling corroded enough to fail. Took it the dealer and they noticed a couple small dents on the muffler and are attributing the failure to an impact and wont cover it under warranty.
The drivers side pipe and muffler coupler look pristine, along with all the other parts of the exhaust, only this joint has corrosion...
Has anyone else experienced this? Is it plausible that an impact to the muffler could cause the connection between the muffler and the pipe to fail on just one side?
Going to have to have it replaced but considering an upgrade. Looking for a somewhat better sounding exhaust but is not that much louder than stock as my wife still needs to drive it. Looking at the Thermal R&D, any feedback on the interior noise level?
I do tow a 4000lb trailer a bit so any drone or loud interior noise under load is a non starter...
