Forscan
KegsBdry
WashDC
If you use Forscan to disable the ‘double honk’ (for instance), can the dealer see this was changed? Would changing something small like that void the warranty?
Fort Benning, GA, USA
its a common and old wives tail that "This *insert modification here* will void your warranty.. theres actually a law in place that a dealer MUST prove what you did caused X issue/malfunction... and if they can't they have to honor the warranty.
QwikEVO
Active Duty U.S. Air Force
New Baden, IL, USA
The "law" you're referring to is the Magnuson-Moss Act.
It is a common old wives tale that the Magnuson-Moss Act will protect them from voiding of warranty for modifications that are clearly outside of what may be considered "OE replacement parts" in design or intent. For example, if you install a tune on your car, you can pretty much kiss your powertrain warranty goodbye. If you install lowering springs on your car and your control arm breaks, forget the warranty of it. etc. etc.
Well yea, because if you change a tune your changing the way the engine was designed to run, also if you put lowering springs your changing the geometry of the control arm.. but if you do a tune, and your control arm breaks... they can’t say “BeCaUsE oF yOuR tUnE” etc
That’s what I was implying.
Jshaffer3819
Kaiserslautern, Germany
I am new to Forscan and just did a couple minor changes which led to more questions.
1. Do we update the “As Built” module or the Other one? APIM As Built or just APIM?
2. When it asks me if I want to load a precious profile when I hook up the OBD, will this remove previous changes I made?
3. How do we do a complete backup of the current settings so if I mess something up I can reload it?
4. Lastly, which title is the engine noise under?
Thanks for the help. So much info out there but can’t seem to find these specific answers.
Jshaffer3819
Please disregard my questions, I found all the information on the Foscan website. They have a great tutorial.
QwikEVO
New Baden, IL, USA
The burden of proof is on the dealership to prove the modification caused the malfunction/damage.
For most bolt-ons, that would be difficult to argue. But for tunes it is quite an easy argument to make.
