Aftermarket Wheel offset question
Atlanta, GA, USA
Hi all,
I am getting ready to order a set of wheels/tires for my ST and had a question regarding offset. I am looking at Blaque Diamond BD-F18 in 22x9 with 275/40zr22 tires. My question is the stock offset is 37.5 for the 20" wheels with 255 tires. The place I have been speaking with is quoting a 22x9 wheel with +15mm offset. I dont have a lot of experience with wheels. Would the offset be specific to the wheel or should it be closer to the factory 37.5? What would be an ideal offset as I dont want to mess with the factory fitment and ride quality. I did locate a calculator and looks like +35 may be my best bet. Thoughts? Thanks in advance
Riverside, CA, USA
Have you checked on Tirerack? There are some tire options for 22" tires.
EG7047
Atlanta, GA, USA
Yes, I looked on there. The wheels are +30 through +38 offset for 22x9 which is another reason I am concerned about the measurement on my quote. It is possible that it is a miskey but wanted some input from folks who know better than I before I answered the quote.
Vero Beach, FL, USA
+15 is gonna stick out and when you turn it will rub up front. You need to stay around + 30’s
I’ve been looking also. There’s not a lot of room in the fender well. There’s a member on here that went 24”x10” with 285/30/24” tires. He said no problems with rub
Vero Beach, FL, USA
Hi all,
Run that chart with a +15 offset.
EG7047
Atlanta, GA, USA
I just located a calculator and looks like +35 is my best bet. 2020-04-30 (4).png
Toronto, ON, Canada
Hey guys
I called my buddy just to double check my offset my wheels are 35mm offset 24 by 10 niche for tires I went with a 284/30/24 nitto 420
It looks tight under there but no rubbing. Hopefully that’s still the case when h and r finally releases a spring lol
Vero Beach, FL, USA
Hey guys
Yours looks great! Do they stick out a little bit? You got a pic down the side to see offset? Stock is 37.5 offset
Jax, FL
Jeffola
Coral Springs, FL, USA
I read the stock 20” offset is 44.5mm. The 21” is 37.5. Just an FYI.
Toronto, ON, Canada
24 by 10 niche with 35mm offset
285/30/24 nitto 420s tires
the ride is actually a bit better with the nittos I suspect because they are soft hahaha I will keep you guys posted on how long they last
There wasn’t a lot of options in a 30 profile 988B0A09-E3DA-44DA-97F8-2F0CD8FB5799.jpeg 988B0A09-E3DA-44DA-97F8-2F0CD8FB5799.jpeg BFBF32C8-7A42-4B87-BFE6-B4F850828C63.jpeg
Tucson, AZ
I love those wheels but man the wheel gap is huge with those tires.
Toronto, ON, Canada
I know lol. Steeda told me they are releasing springs and sway bars in the next couple weeks. I have my fingers crossed
Davenport, FL, USA
Hey guys
Can you post some pics? I’m trying to see what a 22 or 24 x 10.5 looks like. I also would like to see the 20x 10.5 or 11 looks like.
Toronto, ON, Canada
Ford body shop sanded and painted it for me. I looked for a wrap which would have been cheaper but we couldn’t find a blue that was close
New York, NY, USA
The dealer did it or an authorized body shop or something? How much did that cost?
Toronto, ON, Canada
My dealer has an on-site body shop. I had the truck for a few months before I had it painted. It cost me roughly 2000.00 US to have the work done. I think they spent quite a few hours sanding down all the small dimples on the flat black panels.
