Takes literally 2 minutes to get to it.
Pull the push pins around the perimeter of the trim, lift the whole trim piece up towards the hood and the groove that fits onto the bottom of the windshield will release and you can set the whole panel out of the way. The cover on top of the battery just snaps on….pop that off, remove the terminals and push the wire out of the way and unscrew the hold down.
There’s absolutely nothing hard about it. There’s more than enough room to work in there.
