You only quoted part of my post. If there's anything in the bulk of my post that is wrong, you're welcome to let me know. Unless you just want to emoji me to death!
But class, what have we learned interesting today? Our ST uses vacuum referenced wastegates. Which means they can be open regardless of boost pressure. This means they can be open when tooling down the road or at idle, etc resulting in better fuel efficiency as you don't have to put extra power into driving the turbines when not under load. It also means there's a vacuum pump of some type hiding under the hood. I've heard of this on diesels with VNT, but didn't know it was on the ST.
We also learned that the Ford ecu is calibrated to use a torque demand strategy (don't know if this is measured in lb/ft, newton/meters, lbs/min of airflow, or furlongs/fortnight) which allows it to adjust boost (and possibly cam timing?) based on that demand.
I also learned that the stock boost is between 15 and 20 psi which seems suprisingly high to me. I had only asked out of curiosity. I also learned that I need to be more careful when typing since I posted 1.8 bar- about 26.5psi when I meant 0.8 bar which is about 12 psi!
Is this better, I quoted the whole thing? I also corrected my post above…”Yep, I have no clue…”. Just in case it doesn’t come through in the typed word…that was sarcasm.
All of the above is diarrhea of the keyboard.
Let’s summarize for the class…
Boost on a EcoBoost means ZERO in the logic and is a means to an end. Torque demanded is King. There is a lot more that happens between.
I have tuned diesels…it was 15+ years ago. I started looking at my first EcoBoost 7 years ago, and realized I was out of my league, then I saw the tables for a 10Speed, like the 10R60 and knew yep, I’ll leave it to the pros.
Went through a few tuners with my Edge Sport before I stumbled across this Adam guy who wanted to get somebody with a Edge to try higher than E30, and I said what the hell. Been using him ever since. I do Tech for a living and have a BS in Chemistry. I have driven some serious Race Cars(that go both left and right, not just straight) in my 30 years of driving. Don’t know it all, not even close. But nothing I have typed in this thread is incorrect. Might not use the terms you want, but not incorrect.
No more from me in this discussion cause well…pointless. And just because you seem to like them…here is more emojis…
