Hey guys! Who has some serious interest in running e85? Although we do offer e50 tunes there is still power left on the table, especially on the big end of the track. and if you don't like mixing this is for you!
Xtreme DI offers 2 different HPFP fuel pumps for the ST
The HPFP-35 (specially modified for this platform, more details soon but the pump is available now). This pump comes in at $1599 and will support e85 on the stock turbos.
The HPFP-60 is the big brother of the HPFP-35. It supports 25% more flow and max pressure of 3625 psi. This pump is currently the biggest pump on the market and will support large turbos and more modifications. This pump is priced at $2499.
Injector upgrades are a ways out yet however the factory injectors will support full e85 with either pump and the stock turbos. The factory in tank fuel pump has also proven to be sufficient so far!
As far as tuning goes, I offer custom calibrations that support e70-e90 to account for the variation in fuel at the pump. Full flex fuel is not available at this time, if there is enough demand and someone is willing to put in the time data logging it may be possible as some of the flex fuel logic is present in the ecu. It will likely give up a little bit of power compared to dedicated e85 tune.
I only use the HP tuners platform for many reasons. All custom tuning is done with the HP tuners MPVI2 which is a laptop based application. The normal cost of the package is $699, however if you want to bundle with the pump I can definitely work out a package deal for you. Also if you are willing to dyno or run at the track their are more discounts to be had.
The goal of this thread is not to be an sales add but rather to get everyone talking about e85! So let's hear those questions!
- 1
- Show All
