Has anyone done Bora spacers?
Shakopee, MN, USA
Wondering if you had to shorten the existing studs to get them to work. I have 1”
Buffalo, NY, USA
Anything under 1.25”, you’ll have to trim the studs. I just ordered 1” front, 1.25” rear. Lots of guys run 1.25” all around it seems.
Rochester, PA, USA
Yep, 1.25" rears required no trim. My .75" front needed .5" trimmed off the studs
Hope, BC, Canada
Just ordered 1.25 front and 1.5 rears last night. Looking forward to these being installed.
ARC
Oak Lawn, IL, USA
2022 ST Black
I did the 1.25 on the rear with no issues.
I want to order 1inch for the front and I think they will work w/o a trim?
Has anyone tried 1inch on the front.
Hope, BC, Canada
You'll have to trim anything less than 1.25 front.
ARC
Oak Lawn, IL, USA
2022 ST Black
So I wonder if 1 inch spacers will work without trimming?
Buffalo, NY, USA
I think anything less than 1.25” requires trimming.
I nipped .25” off my fronts to accommodate 1” Bora spacers.
Bridgewater, New Jersey
I had to trim my fronts with 1" n did 1.25" on rears without trimming..
Westfield, NJ
I ran 3/4 front and 1 rear. Had to trim both to work with stock 21" st wheels. Upgrading wheels now and had to replace front studs to have enough thread for the new wheels (easy job). I tried 1" front and 1.25" rear originally and didn't like all the crap being kicked up by the edge of the tires. In my opinion 3/4F 1R gives you the most flush look with stock 21 wheels and tires.
