So I was playing around with forscan the other day, and I decided to enable the fog lights to be used as cornering lights (I don’t typically run my fogs all the time anyway) for when you turn, which basically uses the respective left or right fog light to illuminate when you use your turn signal and the headlights are on. What I also noticed was that apparently whether or not I use the turn signal, as long as the headlights are on and as soon as I turn the steering wheel to the left or to the right that respect the fog light comes on also, which seems kind of cool, has anyone else done this and noticed the same? Just curious
