Rear end damage
Kansas
2022 Rapid Red ST
The Explorer Hybrid has 318 HP and 322 lb-ft torque. The Aviator Hybrid has 494 HP and 630 lb-ft torque. Considerably more than the Explorer.
Buffalo, NY, USA
Wondering which part is on the vehicles at the S/T Experience? We will be going to Asheville, but not until May. If someone here goes sooner, maybe you can take a look? I am guessing the 4 Bolt.
Redrocket
Warren, MI, USA
Hey guys just want to chime in here I have a 21 st with the lms stage 4 tune, whipple ic, jlt catch can, and an mrbp cat back. Car came with the 1/3 subframe, in December it failed. Dealer had the car the entire month of December due to back order on parts but they did replace it with the 2/4 subframe under warranty stating it was a mis manufacture.
Thanks for that tidbit of info. Glad you got it taken care of!
st8
Bel Air, MD, USA
Curious, did they ever comment on the tunes and modifications you had done? But yeah, glad they’re addressed it. So that’s an admission that the 3 bolt is wrong.
Redrocket
Warren, MI, USA
No never commented on my mods. I did reflash to the stock tune before it went in however…. Even tho I’m sure they could still see it was tuned prior
Good to hear the dealer said is was a mis build. That might help others to get the part replaced with the correct one.
Detroit, MI, USA
The vehicles at the ST Experience we’re all 2020s,
and yes they have the 4 bolts.
Travis
Shakopee, MN, USA
This is great news, curious-which dealer did you have this experience with?
FORZDA3
Gloucester, VA, USA
The overwhelming problem I see is that it must fail before Ford will fix it. The folks who go in to Ford dealer because they know they have the wrong subframe seem to be blown off.
I still need the B/U camera software update (it’s obviously a temperature-limit related problem because mine only blanks out in cold weather).
I will identify the “mis-build” to my local Ford dealer and see wtf they will do. Even if they agree to do the work, I’m not letting them unless I’m impressed with the “Technician” assigned the job. I already have the part, so I’ll do it myself if the tech is a goon.
It would be nice if we could hear from someone who actually works at Chicago assembly and get the real reason why this change was made. Was it done because of the bean counters or a supply issue?
Temple Hills, MD, USA
I just bought a used 2020 ST and while at the dealer I peeked under 2 brand new 2021s. Both were 2/4 subframes.
If you can, can you post the work order that they gave you? I'm curious about their wording for this as a mis-build.
That's interesting. I've not seen anyone with a MY2021 or 2022 built after 12/2020 say they have a 4 bolt. It would be nice if there were some out there. I think it would support that 3 bolts were mis-builds and not a running change.
Just FYI I was at the Cincinnati New Car Expo today Ford didn't have any ST's on display. However they did have a couple of Timberline Explorers there. I checked them and they all had the three bolt rear sub frames.
Redrocket
Warren, MI, USA
Redrocket
Warren, MI, USA
Hope that helps it doesn’t exactly state a misbuild but that’s what my service writer kept telling me
Redrocket
Warren, MI, USA
STOP! I think you have missed the details in my earlier posts. The MB5Z-5035-E is the latest version of the 4-bolt subframe for all applications that require 4-bolts. I have the correct 4-bolt part, that I ordered through TascaParts.com, sitting here (well, outside under my RV). Order the MB5Z-5035-E as it is the correct 4-bolt part. Note it took a long while to get it, so you won’t find one with persistence. Just order and wait…
Can confirm that mb5z-5035-e is the 4 bolt subframe as confirmed in the pic of my work order.
