Hey, I installed mine a couple of months ago and it was pretty easy. I used painters' tape on the rear one to outline the position and then used a very small knife (scalpel) to gently slice between the vehicle and the emblem (stay close to the emblem). While cutting a little pressure pulls it off and the remainimg tape just peels off the vehicle. Peel and stick the new one using the painters' tape as a guide. Front one is easier as it it smaller and the grill is designed for the emblem to only fit in one spot. Good luck.
