I had almost given up on getting a set, considering Detroit Wheel and tire wants $2700 for a set and that is unmodified. Factor in $250 to get the hub bores opened up and who knows how much to get them widened, I would be quickly approaching 4K for a set of heavy factory wheels. I could get a new set of vossen HF-2's in a 22x10.5 for $3800 and they would be structurally stronger than widened cast factory wheels. Once I found the set on ebay, and after searching the Cleveland area, there was only one shop who could open the hub bore and no-one locally could widen them, I gave up on the idea of getting them widened. Also the size tire I've chosen to run can be mounted on a 22x9 wheel, they are at the minimum of the recommended wheel width. Not ideal, but I'm not tracking my ST, it's a daily driver so a 9" wide wheel will be fine.
Here is the vossen HF-2's, they remind me of the snowflake wheels on the 77-78 trans am's
