its starting to come together. how are are going to modify the panel that fits over the sub? looking forward to hearing it.
Slowly but surely. The panel is not great but not horrible either. I will take a pic later. I have trimmed the panel to within an inch of final trim. The cutout pretty much goes from the bottom of the trim panel to as high as you can go before you get into the angle towards the window. Once I install the sub permanently I will do final trimming. The enclosure sticks out about an inch from the panel final position so I will likely try the SEM
@UNBROKEN used to texture part of the enclosure then I will need to find some type of trim piece to go around the trim panel so it looks normal instead of a lousy plastic edge. That and some closed cell foam where the panel meets the enclosure.
I also ripped apart the amp rack and started over. I finally figured out my venting airflow and I decided to stack the amps towards the rear of the car and ventalate accross the amps. All the hot stuff goes towards, amps and solid state relay so it stays cool and cabling and the fan controller will go in the other half. Might even have a small storage area in the bottom section if I have enough room.
@UNBROKEN , I do like that the very back is vented to the outside on both sides. Thats why I moved everything to the back so I will just have one air channel on the left and one on the right. Hoping because it vents behind the trim panel means that I won't hear the fans.....ever. I'm putting in 4 120mm Noctua computer fans on a controller and I can't imagine ever needing them to run full speed but you never know until you seal everything up.
