Hello everyone i just purchased a explorer platinum and was told it has same engine as ST just needs tuning
Cause when i put it in sport mode it has some kick to it
So does it have same engine as ST
If you don't care to make yours more closely perform like the ST, you can skip the rest of this comment...
I'm expecting to take delivery of my Platinum Explorer next week. Ford matched the performance of the ST on the Platinum and King Ranch trim levels for the 2022 model year. I wanted an ST but liked more of the comforts of the Platinum. Since the power was the same I figured I'd just modify certain aspects to get it closer to the ST and have the best of both worlds. I've since discovered that there are a few subtle differences in styling as well (aside from the obvious platinum grill, trim, etc.). The gearing, as has been mentioned, is different. Likely cost you a few tenths of a second. I'm currently looking into getting part numbers for the gears in the ST and looking at swapping them over. The lower in the front bumper is also not as sporty/aggressive. I like the look of the STs lower better, so I've found the part number for this and will be swapping that out. Lastly, I believe the suspension in the Platinum is targeted more for comfort. I'll be lowering mine with the Steeda lowering springs and will be swapping out the shocks and struts as well. This will firm it up and should be closer to if not have the same handling of the ST. I'm told the Steeda shocks and struts are rebranded OE STs. I found sale pricing on the Steeda's that were less expensive and opted to go that route. A Steeda rear sway bar helps stiffen things up as well. H&R also has lowering springs, and I believe there is a front and rear set by another company available now as well, though can't remember if that was aFe or someone else. There are a ton of threads on various members' experiences on the various parts. Just have to choose what best matches your goals. There are a lot of experienced members on here with a WEALTH of knowledge. This forum has definitely proven to be a rabbit hole for me and will cost me thousands more in modifications as a result
