In the 2022 model year Explorer, the push to start button dropped the green led that the earlier model years had. I know that a number of folks on this forum aren’t fans of that led but having had it on my 2014 Explorer, I kind of miss it. Long story short, I went and bought an older push the start button with the led in order to do what I thought would be a simple swap. Well it turns out that the connector on the back or the 2022 push to start button and of course the wiring harness that connects to it has changed and it isn’t a simple swap. Same number of pins between the two but different connector. Foolishly, I didn’t take pictures of the two connectors before putting things back together. Does anyone know if the pins are a straight match and I just need to make a pig tail with the correct connectors on each end or if there is a difference and if so, what the correct connections would be?
Thanks in advance.
Thanks in advance.
