Wastegate Rattle??
Safety Harbor, FL, USA
Took my ST into the dealer for an oil change and mentioned that I am hearing a rattle when passing parked cars, walls, etc. Pretty much anything that noise is going to reverberate off of when driving past. I mentioned I thought it could be the flex pipes, heat shields or another exhaust component but I could not pinpoint. Service advisor stated it could be the wastegate that rattles and it's normal. Has anyone been told this or experienced this?
mcfarlrm
Update.... Picked it up from the dealer. Rattle was the flex pipe and not wastegate. Worm clamp TSB did not work so new flex pipes have been ordered and back ordered of course. They mentioned it is a different OEM sku that has been updated to correct the issue to replace the factory installed OEM sku. Only time will tell if that is indeed the case.
flex sections. The only remedy is to replace them with aftermarket ones, regardless of what the dealer tells you. Lethal Performance has new midpipes, or you can go full Thermal exhaust.
mcfarlrm
The worm clamp that they installed actually make the rattle worse!!! Do you have a link to the midpipes?
mcfarlrm
Thinking about purchasing the entire Thermal cat back exhaust that includes the flex pipes. This looks to be the one of the few true cat back exhaust systems out there compared to Borla, MBRP, etc. Do you know if the sound is more on the low growl spectrum? Don't want the investment to sound like a ricer fart box. Also, not a big fan of the thermal tips so wondering if those could be easily swapped out. I would probably receive the exhaust before Ford even receives the backordered flex pipes that will most likely not remedy the issue.
I've been completely satisfied with the Thermal R&D product, very well made. The flex pipes are a different design than OE and seem to be very nice. The sound is a bit loud at first start-up but settles down after a minute or so. Not loud when driving unless the pedal is on the floor then it's got a real growl but it isn't a ricer with a fart can sound. There is zero drone. I'd highly recommend this product.
mcfarlrm
Do the flex pipes rattle at all?
No, completely different design. They are a mesh and have been used for years. Why Ford decided to use the flex joint they now use is probably a Dollars and Cents issue but I believe it to be an inferior design. flex joint.jpeg
One of my OE flex sections failed after less than 3 years. If it's rattling, you can be sure it's going to fail from all that vibration/movement--just a cheap and crappy flex section. Since most of my exhaust is stock except axle back, I opted for the Lethal Performance mid pipe. Easy install and fits perfectly. Rattle gone.
Huntington, NY, USA
How big a job is the flex pipes? Can I do this with ramps on my driveway or do I need a lift ?
You can definitely change flex pipes with a set of ramps or a pair of floor jacks and stands.
