I have, it's not soft and it's not thick. I can get a 90-degree pick behind it from the hole. It's panel glue. It is not evident on the left side you simply see the step down from one panel to the other.
You must have missed it, it's not foam, it's panel glue. There is just a void behind two overlapping panels and glue has been pressed out there. It isn't thick, spongy or take up any real space. Sloppy? Yes, but not a foam filler.
