I installed a set of Steeda lowering springs about a month ago. I noticed a slight camber - approx 1.5" - 2" in the back, leaning in on top.
I contacted Steeda to see if this is normal, but haven't gotten a response. Sent them my alignment results, and they show the alignment is within specs.
I was curious if anyone else has had this issue, and knew of anyone that makes a kit to adjust the camber to bring the wheels into a straighter look?
On another subject. Has anyone else experiencing a surging as the car is slowing? It happens as the RPM's go below 2000, then surge back up to approx. 2200. It only does this below 30-40 miles per hour.
