Regular or Premium
StBob
Scottsdale AZ
I am a new Explorer ST owner and wanted to know if using 87 vs. 91 octane degrades performance noticeably.
If you run your vehicle hard or tow, 91 is the way to go. If not, 87 is fine. It won't give you as much HP, but is isn't that big of a loss. Maybe a 10-15 HP loss.
Maven
2016 Explorer
Is somebody checked loses with dyno stand? I thought that car will adopt to fuel and has almost the same HP
Honolulu, HI, USA
Why get a ST and not use premium? I f you want to use regular grade fuel, purchase a model with a lesser engine that is rated for it.
No, it would adopt to it, but won't make as much. Don't know if there is a dyno specifically for the ST, but other vehicles have shown different results.
Because some of us want to save money and not wast it. The ST is shown it is able to take 87.
Maven
2016 Explorer
You right, Ford seviceman says to me that boost of engine lowered when using 87 against 91. Also he says, that 93 is get max boost and did not significantly increase mpg
It really doesn't help unless yout towing or extracting tenths of a second off quarter-mile time.
I agree. Where I'm at it's 90 cents a gallon more for premium 91 octane versus 87 octane. 93 octane is near impossible to find here.
San Diego
Couldn’t you go middle of the road with 89?
We don't have that. Closest is E15/Unleaded 88 octane. Not sure how I feel about it and I haven't seen any reports from anyone using it.
N. Florida
Here, 93 on interstate trips, 87 on the eight-mile, twenty minute commute. Fuel-cost-per-mile is a bit better on 87. It got 26.4 on the interstate in July (avg 24.2). The commute is averaging a bit over 20.
2manycars4me
Marion, IA
2023 Durango SRT Hellcat
93 all the time. Here it is about 50 cents a gallon difference. Normal fill up is about 10 gallons so about $5 difference. I won't go large on that drive thru next time and put it in the tank.
There are at least three other threads that address this, but for the most part you're arguing apples/oranges. The key thing to understand is that an open throttle high-load application is very different than a part throttle low-load operation. Here are my thoughts on the matter.
https://www.explorerst.org/threads/premium-gasoline.1512/post-54146
For those not willing to follow the link, unless the 87 blend has a lower BTU content, at PART-THROTTLE loads, there is no reason 93 will give you better fuel mileage.
No argument from me. Just stating why I use 87 Octane.
What are your thoughts on using E15/Unleaded 88 octane ?
I think it's all a bit of a crap shoot based on the variety of gasoline/ethanol content fuels, and their variability. For myself, if I were taking a long trip on an unmodified vehicle, I wouldn't worry about it. An 88/15 model would probably not give the best mileage. On the other hand, if you're looking to make the best times, then I'd probably go with a 93/10 fuel. If you're modified with a tune, I'd follow the advice of your tuner. There are just so many variables in fuel quality, learning adaptations, etc, it's very hard to give specific advice.
However, the days (if they ever existed) of perfect octane ratios at the pump are gone- as are the days of half-assed knock control. You're just not going to find your engine with overlapped rod bearings or piston holes unless something goes majorly wrong with the sensors.
N. Florida
We're back to a $0.20 difference at Costco. Last summer it was $0.50. Still, 87 is more than adequate for my commute. We were going on a road-trip to Pensacola to visit the NAS Pensacola Air Museum, but apparently the base is closed to taxpayers for a while. Even that journey would only use a tank of gas. Maybe the Plains Car Show in April?
Saltlife911
florida
I am a new owner as well and use 87 octane and dont notice any significant difference.
