The intercooler isnt bad, but you honestly have to remove the front tires.
I did mine one side at a time with a jack and no help.
I would hawever note that you should have a plan wor the shroud bottom rivets - if you dont have bolts there.
I used stainless steel rivet nuts and Rustoleum to protect the drilled out holes.
Start in the morning and with breaks, you'll be done by dinner.
Consider doing upgraded hot and cold charge pipes while you're in there - there will never be a better time.
ps, The fender bolt orientation was done by an a**hole, they tilt UPWARDS. Use universal joints and patience.
pps, Get some replacement wide zip ties from Home Depot to have a tight reinstall.
