Aftermarket Exhaust Burning Smell
Safety Harbor, FL, USA
I just installed a Thermal R&D 2.5" exhaust with mid pipes. After driving I notice a plastic like burnt smell. Is this normal? It's been a week since the install. I checked to make sure nothing is in contact underneath and near the exhaust tips where they are close to plastic trim pieces and all is good. I have read that new exhaust will burn off oils/grease used in the manufacturing process.
FORZDA3
Gloucester, VA, USA
Yes, sometimes there are “smells” from the new hardware, but not plastics smell. You may have snagged a Wally’s bag that has melted.
mcfarlrm
Yep, just as you suspected. Looks like I caught a grocery bag or something on the road.
mcfarlrm
Now the question is what is the easiest way to remove this?!?!
FORZDA3
Gloucester, VA, USA
Easiest way is let it burn off with some wot pulls and high speed runs…️
mcfarlrm
Hahaha I was thinking the same. May have to scrap it off after one of those runs while it's still melted.
FORZDA3
Gloucester, VA, USA
It may flake off if you spray it with water while it’s at full hot temp. No question it will burn off in time, though you’ll smell it along the way!
