How-to: Front climate control swap(add 20-21 temp display to 22+)
Columbus, MT, USA
Just purchased one and now I need to buy a forescan license to write the as built onto it. 105 bucks from livittown ford not too shabby at all…
Damnit Randy!! I might just have to purchase one. I already messed around with forscan to get rid of FENG and double honk so I'm just educated enough to be extremely dangerous
randyknight
Chelsea, AL
I’m the same. I got rid of the fake engine noise, disable the turn signal bulb out for the LED turn signals for the rear so they don’t rapid flash, disable the double honk, and set it to keep my fog lights on even when the highbeams are on. I also adjusted the heated seats up a few degrees in each setting to get them a little warmer. Working great.
I like seeing the temp on the control panel but I have to admit, I almost always look at the screen before I remember to look down.
locoliberty
locoliberty
michigan
Thread Starter #44
You can get a 90 day forscan license for free FYI
#45
Where did you find the setting for that? I would like to bump mine a few degrees on the low and medium setting. High is warm enough, almost too warm.
dolsen
Louisville, KY, USA
#46
I was going to say the same thing, but it is a 60 day license. It is still free though and you can get unlimited free licenses to the best of my knowledge
randyknight
Chelsea, AL
I think it was in the Climate section. seat heat high low and med. its in Celsius.
randyknight
Chelsea, AL
I have already done that to make all my changes I stated above in another comment. So I need to just buy the extended. No harm in giving them some green backs for a great product.
Bought this off Ebay for $100 shipped. I took it apart last night. Just to look inside it.
Going to install it today.
She working.
Back up the old HVAC As-Built and reflash to the new unit.
randyknight
Chelsea, AL
She working.
Nice. Mine is supposed to arrive today. I hope I ordered the correct one because I have heated and cooled seats and heated steering wheel. I ordered one that was posted above that supposed to have everything.
You should be golden.
You will need a Torx to remove the A/C Unit from the bezel. I used a T-20 its alittle loose but it worked.
locoliberty
locoliberty
michigan
Thread Starter #53
Whats your PN for no heated seats? Im going to update the OP as a short guide
randyknight
Chelsea, AL
Decided to make a video in the install.
HVAC control upgrade on 2020 - 2023 Ford Explorer. #explorerst
randyknight
Chelsea, AL
Thank you sir, this one was more difficult to film and get the detail i want in my videos because it was just me and my phone, but I think it turned out good all but the mistake on the intro I saw this morning,. lol
locoliberty
locoliberty
michigan
Thread Starter #58
Adding video to first post
Sacramento, CA
#59
so i guess i didnt follow when you were in forscan. you saved the stock config, installed the part then reloaded the stock config again? what did you change in Forscan?
randyknight
Chelsea, AL
Don't have to make any changes. just load your as built onto the new unit is all I did.
as I said in the video i do not knw if this is absolutely necessary, but a previous post in this thread said it was so I did it.
