I'm looking at a set of RTR wheels that are 20x10.5 et 45. I was planning to run 295/45r20 tires, however, I'm worried the 45 offset isn't going to work on this. Ideally I'd like to be at et30 but running 15mm spacer without trimming the lugs is apparently impossible... My ST is lowered on HR springs and I'm currently running 1.5in spacers on 21in street pack wheels, is there a possibility I could still use these 1.5in spacers with this aftermarket wheel/tire setup? The final offset with that would be somewhere around ET 7 which is still technically higher (less poke) than the spacers and 21s on it now, but these 21s are only 9in wide, I'm assuming with a 10.5 wheel it's gonna poke out way too much
Or will this setup work with no spacers? It seems from what I've read that a 10.5 wheel with a 45 offset will be very close to if not hitting the strut.
