so i guess i didnt follow when you were in forscan. you saved the stock config, installed the part then reloaded the stock config again? what did you change in Forscan?
"as-builts" aren't programs, the module is already programmed. As-builts are just bits that tell the programming in what way to run based on the vehicle configuration.
- Show All
