Those cars used a hot-wire mass airflow sensor (MAF), so measurement was before the turbos. Turbo blow-off valves (BOVs) upset the air fuel ratio (A/FR) since the air was already measured prior to entering the engine. Exhausting it changes the A/FR, and leads to rich mixtures between shifts. The ST uses a more sophisticated speed density system no longer requiring a MAF. BOVs are meaningless in this situation unless you're addicted to sneezing sounds between shifts.
BOVs were a bandaid for '90s turbo,ECU, and airflow measurement technology. I am honestly pleading with people- stop spending money on stuff that makes absolutely no sense, and quit allowing vendors to sell you crap you don't need.
