D Pillar W/Speaker
Can some post the part # for the D Pillar W/Speaker cut out? (Left and Right) Non-Sunroof.
Look at adding more speaker to my stock 6 speaker setup.
You don’t need to add more speakers. You can do everything needed with the locations you have now. Using your budget for better speakers up front is a better play than adding speakers to the d-pillars.
Stone17
My setup so far.
Front Door : Focal Inside IS FORD 690
Rear Door : Focal Inside IC FORD 165
Audio Control amp and Sub getting installed soon.
Add the amp and sub then spend some time tuning it. Just adding speakers is usually a recipe for disappointment.
Round Lake, IL USA
You got the right guy answering you Stone...his setup is insane. Deff the person to be asking.
I would not add more rear fill either. I think replacing the cheap ford drivers is a good budget play, as is adding the powered sub, but definitely do yourself a favor and sound insulate the doors if you haven't done so already.
Considering he’s already installed some stuff and is about to install more if say a quality round of sound treatments is the best step. If he didn’t have anything installed yet I’d say it’s the first step.
Stone17
When I replaced the speaker, Added Hushmat inside of the door and surround area.
Sound treating a car can get quite extensive if you let it. What you did is certainly better than doing nothing but there’s a lot more to be done that can get you some pretty dang good results if you ever decide to dive in deeper.
