Hello Everyone,
I'm new here, but not new to cars or modifications. I've got a problem however that's got me (and friends) absolutely stumped. We had taken a day to install all of the modifications below, I knew after the lowering springs that I would need an alignment, and rightfully so the toe was pretty far off (it could be felt while taking it to the alignment shop). After the alignment things were much better, however now when cruising at highway speeds and taking a "curve" to the right or hitting a "bump" such as the transition to/from an overpass the rear end gets very "squirrely" and it is/was very panic inducing (note that it does not doing this if taking a curve to the left).
If anyone has any ideas or have experienced something similar and have been able to resolve that information would be extremely helpful.
Thank You!
-Austin
- AFE MOMENTUM GT COLD AIR INTAKE SYSTEM W/ PRO 5R MEDIA
- THERMAL R&D 3" CAT-BACK EXHAUST SYSTEM WITH MID PIPES
- LETHAL PERFORMANCE LOWERING SPRINGS
- FENFABRICATION "DIFFY STIFFY" BRACE
- Tune from Unleashed Tuning
- AFE CONTROL SWAY BAR SET
Thank You!
-Austin
