FENG - Fake Engine Noise Generator DELETE
Greyghost
Harleysville pa
Well, this kind of raises a question/issue I was having.
I do not understand Forscan or any of that, plan has been to just have PBD do the install. That said, would this mean they can disable things like FENG and the key fob double beep?
What would be on your list of "must turn on/off" if you had one chance to have someone do it for you?
1. Double honk key fob delete
2. Side mirror ST logo on with high beams while driving
3. Bluetooth iphone car sync connect (2020 Model)
4. FENG delete
5. Access to full screen mode all time (Nav, entertainment...)
6. Camera access while driving
7. INDEF run time from keyless start
am I missing anything? hahaha
Toadster
Folsom, CA
4. FENG delete
What’s #5 ?
And are you doing Bambi mode?
Greyghost
Harleysville pa
What’s #5 ?
This screen should be all map. The fact it is sectioned off for anything I am not using (audio in this case) is annoying. Seems like an obvious flaw.
Toadster
Folsom, CA
so #5 makes it 'all map'?
