South NC here. I just left them in. Not sure if they ever spend much time closed. Someone correct me if over simplifying it. If you do take them out only remove the shutters not the assembly. Leave everything plugged in
First off the stock intercooler is fine for stock power numbers. I think I would need some rock solid numbers for removing the shutters. I wouldn't mess too much on grille shutters, I dont think it is worth the trouble, and plus there is a reason Ford put them there. I do not think you will see a difference.
the reason for the shutters is the allow for the car to warm up to operating temperature while staying closed. once it reaches optimal temp it then opens them up.
should it warm up without them open? absolutely! will it take longer in an enviroment that has cold winters? absolutely! Are they necessary? meh, not really. Vehicles have warmed up just fine in Fargo ND for the last 100 years without automatic shutters. if the fins are removed without removing the motor there is generally not any codes that will pop up.
They arent necessary vut they help the engine warm up faster, putting less wear and tear on the engine parts. I dont see the point to this mod as I cant see a differwnce that is worth it.
I'd like to point out that the grill shutters aren't used to "help the engine warm up faster". That is the job of the thermostat. In fact, until the engine warms up enough to allow the thermostat to open and send coolant to the radiator, the radiator doesn't perform any function at all.
Sorry for commenting on such an old post but it came up in my reading about the active shutters on these cars. Shutters will absolutely help the car warm up faster. Closing off the engine bay from exterior air in any amount will help to keep more warm air in the bay therefore allowing both the engine and componentry to warm quicker even if it is a minor amount. The more important aspect of the shutters though is the aerodynamic effects that it has. Warming things up is a small additional advantage that they provide.
