If you're going to run spacers, get https://www.motorsport-tech.com/land/toyotac_land.html they are high quality and are hub centric and you can get them any thickness you want. Most run at least 1.25" then the studs just barely stick out and they will fit into the recessed pockets on the back of the wheel so you don't have to cut them.
Look at this pic, see the recessed pockets between the lug holes? That is what I was talking about. If you have factory 20's you will have to open up the pocket a little but the 21's fit just fine.
