Hi All,
I've read a few stories of ST owners and their ICC misreading 35mph signs for 85mph and I've experienced the same.
What I'm not understanding is when I set a speed and moments later, the ICC changes to a higher rate of speed for no apparent reason, even if the speed limit hadn't changed.
When you're in CC, it shows your set speed and the actual speed limit. Every now and then, it will show what appears to be a speed programmed in for that particular speed limit.
I'm guessing that the CC diverts to that programmed speed regardless of what you have set. I'm wondering why it does and why it happens up to a good minute after you've set your desired speed.
Not looking to get a ticket on those roads with photo radar. Is there a way to delete any programmed speeds? Thanks for your thoughts!
