Thread Starter
- Messages
- 947
- Reactions
- 531
- Points
- 82
- Location
- East Freetown, MA
- Vehicle
- 2020 Explorer ST, Silver Spruce Metalic
Thread Starter
The rep at mObridge has me about 80% ready to try their amp. It’s something I’m sure I can do myself. You lose the center and D-Pillar speakers but you gain headroom and better control of the sound. If I don’t like it I just need to unplug it and send it back. It comes with a 30 day warranty, even if you install it. That says something because 99% of electronics can’t be returned once they have been installed! The only thing you’re stuck with is the custom wiring harness they have to make up which cost like $50. The hardest part of the Install is running a power wire from the battery to the amplifier and that shouldn’t be too difficult. The way the rep explained it to me is, the amp has 8 regular channels, a subwoofer channel and one set of RCA outputs to add an external amp. The front doors are run actively off channels 1-6, the rear doors passively off channels 7 & 8 and the sub off channel 9. The reason I’m not 100% is because of all the conflicting information I’ve found about how the speakers are wired. Most of the diagrams show the rear door speakers wired together with what looks like some type of crossover. The best way to do it is like UNBROKEN said, rip out everything and replace it. You just have to find a shop you’re comfortable with. Either that or do it yourself.
