Heated steering wheel barely works.
LONESTRAT
bristol,rhode island
Heated steering wheel barely works. It is working a little, but I feel like it should be at a higher temp. Is there a way to adjust the level of heat it generates?
Not aware of any method to increase temp. Having said that, I will say that mine gets pretty darn warm.
You can adjust it with Forscan.
L
LONESTRAT
Thank you. I don't have Forscan. Do the Ford dealers have it?
No…it’s a free program you use yourself via the OBD port. Super easy to use and lots of info online about what to change to get the result you’re after.
Nice. Didn’t know forscan worked for that. Learn something new every day.
DaveG ST
Hurlock, MD, USA
You may notice more of a difference when it gets colder outside.
Round Lake, IL USA
Was just going to say it may depend on how cold it is when you use. Subjective but the modifying temp through FS is only way I know of.
