Oil capacity
MY2020ST
2020 explorer ST
First oil change on the (new to me) 2020. Put in 6 quarts and a new oil filter. Dipstick is reading well below the mid-point indicating it still needs more. Oil containers were sealed when I got them and I didn’t spill any when pouringthe new stuff in. Engine was warmed up when I checked it. I‘ve done tons of oil changes on other vehicles and don’t remember seeing this. Has anyone needed to put in more than 6 quarts?
6 quarts is recommended. Check your engine when it is dead cold. These engines as well as the 2.7 engines take a good minute for everything to drain back into the pan.
M
MY2020ST
2020 explorer ST
Thank you. Looks like you were right. Dipstick says it’s full after 3 hours of allowing oil to drain back to the oil pan. I appreciate your response.
I run seven quarts Mobile 1 5W-30. It's overfilled to prevent low oil pressure on acceleration. Appears to be a half quart over full when checked.
I overfill for the same reason. Not sure what kind of baffling the pan has. Put an aftermarket oil pan on the CTSV I was road racing and it had really nice baffling compared to the stock. Not sure there is any baffling in the ST oil pan so better safe than sorry. No oil pressure leads quickly to bad things
And at what point does one know when the level is high enough to be interfering with the crankshaft? Even with engines that have good baffling and windage trays, you can drown the crank. In effect, slowing it down.
Rick
Fort Hood, TX, USA
Rapid Red
Too much oil in the engine can also cause the pressure on the crankshaft to increase, causing oil to enter the exhaust pipe from the crankshaft into the combustion chamber, blocking the combustion chamber hole with oil and eventually clogging the engine. Wet spark plug; excess oil will also flood the spark plug well
Rick
Fort Hood, TX, USA
Rapid Red
You, sir are correct
IMO you get your oil a little whipped and aerated if you get into the crank. 1/2 inch should not really affect anything. It should not be into the crank with engine off when checking level. It certainly won’t be when running the oil pump as oil is off the dipstick with engine running.
That was my point, how do you know? I expect you'll be fine.
That said, the pans on these aren't deep at all. How far up the block skirt is the actual level? The picture below shows just how small the oil pan is, much of the oil is up into the skirt.
I understand the desire to give the engine a little extra protection under hard use but I've got to wonder if there isn't a little placebo effect going on here. Now if you're making a left-hand turn for hours on end, well... NASCAR takes that into consideration.
But look at the height of the centerline of the crankshaft. It's a long way from there to the bottom of the oil pan. @Cruising68 is right, adding a half quart more oil isn't going to affect the crankshaft once oil is displaced to the upper end when running.
ZRX61
L A, CA, USA
What?
FORZDA3
Gloucester, VA, USA
I always run an extra 1/2 qt in my Raptor and ExplorerST. I’ve removed the “balance” shaft in my 2.3 Focus RS, installed race baffling into the pan, and run an extra 2qts.
