How often are people changing plugs? On the Focus ST (2.0 Ecoboost), plugs get worn out pretty quickly. Many recommend changing them at every oil change, or at least checking the gap.
They're not as easy to access on the 3.0, I'm hoping we can go longer intervals.
What is the consensus on the best plug? Bosch? NGK? Brisk?
Do you recommend staying with the stock heat range on the stock tune?
