BMS Battery Management System
Olds, AB, Canada
What function or purpose does the BMS system server?
Planet Earth
It is designed to save the battery and prolong its life. If the monitoring systems determines the battery has fallen below a specific charge threshold it will start shutting down specific electronics to ensure you still have enough power to start the vehicle.
Here is info from Ford, they use an F-150 as an example but same concept: https://www.ford.com/support/how-tos/more-vehicle-topics/batteries/battery-management-system/
Should note, that anytime you replace the battery it is important the BMS gets reset as well, otherwise it holds old parameters.
l1tech
AZ
21 ST
It actually does more than shut down systems so you have juice to start. It monitors the charging system over time and determines the appropriate voltages to charge the battery taking the battery's age and temperature into consideration. It is important on these vehicles if you jump start or charge the battery that you do not hook the negative battery cable directly to the battery. Instead you should hook the negative to a grounding point on the chassis such as a shock tower bolt. If you hook directly to the battery the electricity flowing into or out of the battery is not accounted for by the battery monitoring sensor and can throw the charge algorithm out of whack. It is also important to reset the system when the battery is replaced to ensure proper charging system performance .
Exist2Resist
Olds, AB, Canada
Thanks for the info.
Ok so BMS is a bit gimmicky and useless in the majority of usage scenarios.
I do know about the reset, etc. But that won't matter going forward as I am disabling BMS along side with Auto Start Stop.
st8
Bel Air, MD, USA
How do you reset it? That knowledge I’m guessing is unknown to the majority of people. I would think the system and design would account for that.
Exist2Resist
Olds, AB, Canada
My understanding is that you require an ODB-II reader and ForScan to reset it.
l1tech
AZ
21 ST
You need a scan tool that is capable. I'm not familiar with all that is out there as I have the factory Ford tooling. The system can not reset itself no matter how smart it is.
l1tech
AZ
21 ST
Why do you want to disable the battery management? It's not like it affects performance in any way and if it helps you get a little more life out of your battery it's a win win.
Exist2Resist
Olds, AB, Canada
BMS is responsible for the Auto Start Stop feature, I have disabled BMS along with BMS Start/Stop. I'd rather have that gone than gain extra battery life. With it disabled I suspect Battery life will stay the same as I will not have the car engine starting/stopping and being drained by electronics while the engine is off, but more importantly I won't by putting unnecessary wear on parts with the silly Auto Start Stop feature/gimmick.
l1tech
AZ
21 ST
BMS stands for Battery Monitoring Sensor. It is not responsible for the start/stop system however it is an input that the start stop system uses. If the BMS senses that an electrical load has been placed on the system it will relay this info to the start stop system and initiate an engine start to maintain battery voltage. The BMS is also a main input for the charging system. Without it you may end up with an over or under charged battery. These vehicles thrive on proper battery voltage and the BMS helps to maintain that. I can see disabling auto start/stop but disabling the BMS serves absolutely no purpose.
Exist2Resist
Olds, AB, Canada
Start Stop is tied into BMS this time around. Under BdyCM there are two options BMS and BMS Start/Stop.
As far as I know other locations disabling Start Stop does not work.
But I think I'll turn BMS back on and leave BMS Start/Stop off, without BMS the door code system doesn't light up.
l1tech
AZ
21 ST
Yes it is tied in. It's an input for the start/stop and I've already stated that but I don't believe deactivating it is going to disable the start/ stop system...that is what you are trying to do isn't it? I'm interested in your progress is doing so.
Exist2Resist
Olds, AB, Canada
It does disable the start/stop system, like I said there are two options in BdyCM, BMS, and BMS Start/Stop, this is where you disable start stop and it works. I've been running with it for almost a week and start/stop does not engage. I disabled both, but I'm going to revert BMS while keeping BMS Start/Stop off. Only caveat with that when you start the vehicle it briefly complains about the battery charging system when BMS is engaged and BMS start/stop is off. I'll see if I can find the option for that some where else though.
The reason I'm gonna turn BMS back on is because the B billar touch keys don't come on with BMS disabled.
l1tech
AZ
21 ST
So BMS and BMS SS both disabled causes SS to stop functioning but causes a charging system fault and some electrical consumers to not function correctly. Am I understanding this correctly?
It does make sense that with both of them disabled the SS system should not work because that is a main input for the SS. It also makes sense that you would have charging system warnings because you have also disabled the charging systems main input.
So with BMS enabled and BMS SS disabled does the SS still function along with no charging system error messages and all electrical consumers still function correctly?
Exist2Resist
Olds, AB, Canada
With BMS disabled and BMS SS turned off there are no warning messages on the dash, but the touch screen on the B pillar is disabled, everything else works.
With BMS enabled and BMS SS turned off there is a warning message on the dash. ASS does remain off, and all the devices work.
l1tech
AZ
21 ST
This is not what I would have expected. Can you put a multimeter on the battery and see what your charging system voltage is with these settings?
Exist2Resist
Olds, AB, Canada
Thread Starter #18
Aren't you able to reset the BMS by following this procedure? Brights 5 times, then brakes 3 times.
I can't see that being a thing. You could potentially do that while on the road and it would lead to a world of issues.
Honestly never put the multimeter on the battery and I have been driving like this now for over a year and a half even through a harsh winter. Seems to be the solution for me.
You do it while parked with the ignition on but not powered yet. There are some pretty convincing Ford techs that claim it works, and if you follow the procedure you do see the battery icon blink. I did this in my Mustang a year ago after replacing the battery, which straight up died and resulted in electrical conservation stuff (like passenger side lock wouldn't function I think), so it seemed to work.
Check this ford service content: https://www.fordservicecontent.com/...a&div=f&vFilteringEnabled=False&buildtype=web
Plenty of other Google hits on this.
Bowie, MD, USA
From the owners manual.
