The included wireless charging pad is not only hard to get to it is bit too small for the larger phones with a case on them. This is my solution.
Amazon.com: Car Charging 15W Wireless Charger pad Fast QI auto Wireless Charger pad Compatible iPhone 12/12 Pro/12 Mini/12 Pro Max/Se and All Qi Enabled Phones: Electronics
I simply cut the wire and drilled a 1/8" hole way in the back of the area where the door is attached and then soldered and reconnected. Plugged in Lighter plug and how have a 12 watt wireless charger. I just toss the Note 10 on the rubber cradle and off I go.
- 3
- Show All
