Quickjack 7000. Wanted a little insurance on capacity.
Harbor freight vacuum bleeder. I have a motive pressure bleeder, which I prefer, but don’t have a cap that fits yet. Also found out the abs bleed procedure in the Ford software assumes you are using a pressure bleeder. Might head to Ford to get another brake res cap I can adapt to my motive for final bleeding including the abs circuit.
As for the ABS bleeding procedure (for BMW), it's similar. It's recommended when you open the system up (ie. replace a caliper, master cylinder, etc.). I think you can get away without doing that if the opening is way downstream of the master cylinder.
