Same car…both intakes…in case anyone is trying to choose between the two and is curious. The S&B in my opinion is better built with better components all around plus its larger and uses larger filters.
Same car…both intakes…in case anyone is trying to choose between the two and is curious. The S&B in my opinion is better built with better components all around plus its larger and uses larger filters. View attachment 21157
I appreciate this post. I'm in between the AFE and S&B and now I'm leaning towards S&B. I do think it looks better also... BTW your ST build is awesome!
Is there any value to a mod like this if I don't plan on any other performance upgrades? The only thing I have done to mine is swapped out the mufflers/tips. Dont plan on doing a tune or intercooler or anything like that.
If you’re not going to do any other mods you should skip the intake. But I highly highly recommend you atleast do an intercooler whether you want to tune or not. A catch can would also be a very good mod to have.
Intercooler and catch can are a must on these vehicles. An aftermarket intercooler is about 4 times the size of the stock! Huge bottle neck there. Also causes heat soak easily.
