Suddenly audio starts to work again !!! After 4 days without audio the system started to work again and I did not touch anything else !!
Really strange isn’t it ?
This is the 2nd time it happens the same way.
What is wrong with the system ? Is there any upgrade I need to install ?
I just got back from the dealer because I was experiencing the same issue, and yes, I tried the “soft” reset and master reset. Apparently a module burned out and needs a replacement. Once they get the part (Mon/Tues), I’ll go back prob Fri to get it replaced. I’ll take a pic of the actual part they replaced for reference.
Good that you’re still under warranty. Wondering what‘s the failure rate for the module and out of pocket cost to replace. Was it a low cost easy remove and replace or something of high level difficulty and cost? If anyone have an idea.
can you please confirm the part number for the module? I have the same issue, and the dealership wants $900 to replace it. I found some on eBay for $400 and I have the ability to replace it myself. Just want to make sure I’m get the correct part with NAV and everything.
Now that I have the module, anyone know where it is located? I have seen behind a panel in the trunk area, but also maybe behind the head until. Any assistance or photos should be a huge help.
Hi Doug, I just also bought one off ebay and did the install and it solved my problem. The module is located in the trunk area on the passenger side. You will have to remove the plastic panels along the interior for easier access. Everything comes off fairly easily.
Hey 22Forged Green. When you did this module replacement, did you disconnect the battery first or just pull the panels and plug it in? I am experiencing this same issue. Has happened off and on for about 3 months and finally no more volume. Thanks!
