Seatbelt display on Dashboard will not go away with 'ok'
brhinminn
Minnesota
The display shows that the back two seats are occupied with seatbelt connected (green) and the other is red (occupied) but not connected. This is brand new and no one is in the bac seat. This is not the major issue. The issue is that the warning will not go away with OK. I restarted the car and still there. Is there a way to reset the dashboard? Or should I try to reset the SYNC and see if that is connected? thanks!
B
brhinminn
Minnesota
1704984982586.png something like this. I apologize, I copied the screen from another thread as I did not have a picture. But it is the above and will not go away with ok. I do wish it were 79 degrees here!!!
Nothing sitting on that seat is there?
B
brhinminn
Minnesota
Nope. But even in the past where something was on the seat, I could hit 'ok' and it would go away.
Tulsa, OK
I've never seen that on my 2020 or my 2023. But, I did disable the seat belt chime right away on both vehicles since I don't always wear my seat belt.
FrankST
PA
did you figure out how to fix this?
23 Explorer ST
Sensor in the seat is bad and needs to be replaced.
