The bolt is NOT upgraded. It's the same grade bolt, just a different manufactured one. I personally think there is no difference between the new bolt and the old--just Ford showing the NHTSA that they came to a "solution". People were pulling the old bolt out of the single rear mount and it was bent--I myself pulled both old bolts out of my double mounts and they were straight as an arrow. Then Ford addressed that the double mounts had different bushings than a single. So that was modified slightly. Again, more window dressing. There would be no issue had Ford kept the double mounts on the 3.0L like the engineers designed. At the very least though, by doing the recall, Ford could be replacing bent bolts that may have failed given another year or two (or maybe not at all) and buy some time. So few or no failures in the next couple of years? Well, I guess the recall worked! (not!)
