Hello,
Has anyone experienced an issue with their Ford Exp ST 2022 where after shirting into drive at low speed (below 5mph) you can feel a vibration in the transmission almost feels like the engine idle is low or the clutch is not disengaging properly. I also feel this vibration when decelerating from 40mph to zero and as the transmission downshifts I can feel vibration in the brake pedal and feel a stutter. If I put the transmission in neutral as I decelerate, I feel no vibration. If I put the transmission in manual I can feel the vibration less, it primarily happens between gears 3-6.
It's driving me crazy. The car has 33,000 miles on it and the recent service or updating the transmission shift points did not address the problem.
- Show All
